ScoutMaster1
Lynden
Utah
Hyundai Palisade, Nissan Juke
Alright, so here's the deal: under 10,000 pounds of towing? Seriously? That's, like, ancient history. 7,500? Okay, maybe we can work with that. But 5,000? Come on! That's basically Explorer, 4Runner, Telluride numbers. I'm totally scratching my head because I reserved the Terra Harvester, and I figured it'd tow like a truck, not some SUV/crossover thing. Now I'm thinking, forget the range, I'm going full electric just to get some decent towing power.
That’s my thought exactly. I reserved the Terra Harvester not knowing the towing would be affected so dramatically. I need 8,000 lbs minimum for the boat. 10,000 gave me just enough cushion to be happy. I guess I’ll have to go pure EV as well and deal with charging. RIP ?
Crossing my fingers things may change in the next two years for the EREV for its towing capacity.
TN <> MI
2021 Jeep Gladiator Rubicon
So here's the AI summary of the performance figures, range specs, and other technical specs from the video:
Performance Figures, Performance Metrics, and Technical Specs:
  • **? Acceleration:
    • 0 to 60 mph in 3.5 seconds (all-electric mode)
    • 0 to 60 mph in 4.5 seconds (with range extender)
  • **? Electric Range:
    • Pure EV range: 150 miles
    • Combined range with gas extender: 500+ miles
  • **? Torque:
    • Up to 1,000 lb-ft of torque, providing significant power and towing capability
  • **⛽ Gasoline Range Extender:
    • High-output four-cylinder engine located on the rear axle
    • 15-gallon fuel tank capacity
    • Operates automatically or manually (EV, hybrid, heavy-duty towing modes)
  • **?️ Towing and Payload Capacity:
    • Pure EV truck: 10,000 lbs towing, 2,000 lbs payload
    • SUV version: 7,000 lbs towing
    • Hybrid mode: Up to 5,000 lbs towing for both models
  • **? Technical and Structural Features:
    • Body-on-frame construction (blend of steel and aluminum)
    • Solid rear axle for durability and torque delivery
    • 800-volt architecture (supports fast charging)
    • Dual electric motors (front and rear) for AWD capability
  • **? Battery Types:
    • Main EV battery: Nickel Manganese Cobalt (NMC)
    • Range extender battery: Lithium Iron Phosphate (LFP) for durability and cost-efficiency
  • **? Off-Road and Utility:
    • Disconnectable sway bars and electronic lockers for enhanced off-road performance
    • Adjustable air suspension (optional) for ground clearance optimization
    • Gradeability: 100% (suitable for steep terrain)
  • **⚡ Charging and Power Supply:
    • Fast charging capability: Up to 350 kW
    • Vehicle serves as a power generator with 120V and 240V outlets (ideal for worksites and campsites)
  • **? Additional Driving Modes:
    • EV-only mode for short commutes
    • Hybrid mode for optimized efficiency
    • Heavy-duty mode for towing and demanding tasks
  • **? Braking System:
    • Four-wheel disc brakes for reliable stopping power
  • **?️ Production and Release:
    • Manufacturing plant in Columbia, South Carolina
    • Production start date: 2027 model year
    • Plant capacity: 4,000 employees and scalable assembly lines
So this is completely out of nowhere.
Description:
Join Jay Leno for an exclusive first look at a revolutionary new prototype that blends classic American muscle with cutting-edge electric technology. In this episode, Jay dives deep into the all-new Hybrid Scout—a vehicle that revives the iconic International Scout with a futuristic twist. Discover how its innovative range extender, 800-volt architecture, and off-road capabilities deliver blistering performance (0-60 in under 4 seconds!) while still honoring its nostalgic roots.
Highlights include:
• Dual power modes: Pure EV, Hybrid, and Heavy-Duty for towing
• Smart engineering built right here in the USA
• A behind‑the‑scenes look at how classic design meets modern tech
Hedrock
Baltimore, MD, USA
I wonder if the tow rating discrepancy is a battery chemistry thing? I’m new to EV batteries, but it shouldn’t be much difference (certainly not 5k lbs!) between curb weight on harvester versus BEV.
Anyone who knows batteries that can chime in on…idk discharge rates? Heat dissipation issues?
Ajangel
Andres
Miami
Ram 1500
They seriously shouldn't have debuted this video with that drivetrain note. It sounds terrible. I know this is a prototype, but yikes.
It was pretty annoying, but not making and conclusion out of today's drive.
That goes to show how much work it takes to develop a prototype and how much more they need to work on to make it fully functional.
FloridaMan239
Naples, Florida
GMC Canyon abd Volvo XC 90
  • *? Towing and Payload Capacity:
Believe he said the range extender in both models was only 5k lbs, it was after the discussion on the 3 driving modes and can be heard at about the 5 minute mark. If so, I'm cancelling my reservation as the towing capability with adequate range is a must have...so disappointed right now
BigFatBalla
Corey
Utah
Terra
Honestly the towing capacity reduction for the Terra Harvester may be the deal killer for me. 5k puts it under my wife's Subaru Ascent. With our current configuration that number is fine with a tent trailer fully loaded coming in at around 4500, but we have been looking at upgrading to a larger trailer that when loaded would put it closer to 7500. Going all electric makes no sense as we take trips currently at up to 350 miles one way with towing. The Ramcharger is touted as having 14k of towing. This really hurts. I LOVE the Terra, but...
Foobar
New York
Ouch. I was hoping the Terra Harvester would replace my Rivian R1T Quad Motor in pulling my Airstream with more range. It has the range but now removes the capacity. This one’s a showstopper for me.
One of the main reasons I wanted the Harvester was range towing a 5K lb TT to the desert, so if this isn't changed by launch time I will have to look elsewhere, Ramcharger? Perhaps he just mis-spoke and it will be corrected, I need at least 7K towing.
Ajangel
Andres
Miami
Ram 1500
Honestly the towing capacity reduction for the Terra Harvester may be the deal killer for me. 5k puts it under my wife's Subaru Ascent. With our current configuration that number is fine with a tent trailer full loaded coming in at around 4500, but we have been looking at upgrading to a larger trailer that when loaded would put it closer to 7500. Going all electric makes no sense as we take trips currently at up to 350 miles one way with towing. The Ramcharger is touted as having 14k of towing. This really hurts. I LOVE the Terra, but...
I get it. I don't do long hauls, is to take the boat to the marina, but I can't even do that with a full size pickup trucks like the Terra... Is just unreal. But the full electric would do the trick at least in my case.
ScoutMaster1
Lynden
Utah
I really hope they keep a tab on the forums. There’s still plenty of time for them to fix this before 2027. We need to get our voices heard.
hozer
Calgary
Suburban
Not sure the surprise here.
Tow capacity is always a trade off for an off-road vehicle and 5000lb is in line with cross shopped vehicles IMO. The notable exception being the GX550.
While this forum likely has a concentration of folks wanting that tow capacity, the average customer regularly hauling 7500 lbs is buying a truck and the guy wanting to overland has a 3000lb teardrop not a 25ft glamping machine. The Venn on both is not a big market and makes a compromised vehicle for both IMO.
Truck I get the letdown, but harvester right in line with what id expected
one30five
Josh
Michigan
2014 Nissan Frontier, 2018 Chevy Equinox, 1981 VW Rabbit
Man, I’ve been so excited about this thing, but if the 5,000 lb tow rating holds on the Terra harvester, I’m out. I can pull my camper with an 11 year old Nissan Frontier, but not with the scout I reserved. Pull through chargers are not nearly enough places for the pure ev when towing for me. Maybe the traveler could fit our household for my wife, but at that point we would prefer a third row.
I take it also a different battery(s) for the Harvester than the EV because the batteries composition type you can always charge to 100% and take lots and lots of charging cycles with much less degradation.
The basic 2WD Tesla 3 has something like that.
Don't hold me to it but that kinda battery may be much heavier than the EV only battery(s), thus towing capacity gets dinged.
Tesla Model Y, BMW X5 45e, VW Jetta
Good video and conversation about the Scout with Jay. Yeah the truck was loud (tranny whine) and you could hear rattles etc., but that is normal for pre-production mules and did not shock me at all. They mention it during the first few minutes of the drive and Jay reiterates it a few times.
Overall still very excited about this vehicle and can't wait to get video's of vehicles closer to production.
