Question about EREV Extended Range EVs on Long Trips (Harvester Gas Engine)
Opus
Jeff
f150
So lots of discussions, but most seem to talk like there is a one size fits all - i.e. it only works one way. I would like to see it have "modes" like my F150 and a lot of other vehicles these days. Something like this:
- "Eco mode": might reduce acceleration or use only some of the motors, have a speed limiter, may lower the air suspension (I think Rivian does this suspension trick, not sure if Scout even has it?), turn off the Harvester, etc to maximize pure EV range.
- "Normal mode": i.e. the 500 mile range, with Harvester kicking in at 20% charge or whatever.
- "Tow/Haul/Max Range mode": Harvester runs all the time charging the batteries and feeding electricity direct to the motors, to maximize range/mimimize battery drain, esp when towing or hauling. (Maybe even detects a connected trailer and turns this on by default when towing)
- "Charge mode": (just throwing this in the mix) - where it can sit still and run the harvester to charge batteries while not driving, say while I stop to eat lunch but no charging stations around. (Ppl have expressed concerns about this running in a closed garage, but having something like a carbon monoxide detector, prompt the user to not run this in an enclosed space, or sensors to detect if it's surrounded by walls/roof, etc to disable this - I'm fine with having to park out and away from things to run this mode. Note: stupid ppl will be stupid - there's nothing that prevents turning on an ICE engine in a closed garage, so it doesn't really create a "new" risk, unless it turns this on automatically when it needs juice, so it would almost have to be a person manually turning this on)
I feel like this would give the best of all worlds - 99% of the time as a daily driver, it's pure EV, but on those long trips or when towing, it makes the most use of the gas engine to extend that range.
Taking this thought experiment a step further...
Looking at max driving range before I am stuck, if all I have access to is gas - no charging stations (probably unrealistic but thinking worst case for an EV noob like me that has no experience with charging stations on the road).
Lets say if I tow in "Normal mode" and (making up numbers), I get ~150 miles of towing range with a full battery and gas tank (lets assume towing reduces range by 2/3rds or so, so 50 miles EV + ~100 miles gas+ev), and then have to gas up and charge up.
But lets say in "Tow/Max range mode", if I can go 100 miles with Harvester running the entire time and run out of gas, but still have 80% of battery, then I fill up the gas, go another 100 miles with battery to 60%, and can do this (theoretically) 4-5 times before I have to stop for gas and charge, and get 400-500 miles of towing that way (and even more without towing), I would be good with that.
If some of the information/speculation I've seen is right, and it can go 150 miles on pure EV (lets assume 50 miles towing), and lets say harvester in "Normal mode" kicks in at 20% battery for another 350 miles (lets speculate 20% battery + a full tank of gas gives us ~100 miles towing, I'm thinking I may not be too far off, and could in theory go 1300-1400 miles between charges, with multiple gas fillups when not towing - that 500 miles, I believe, is range without filling up electrons or gas.) Probably the absolute worse use of an EV vehicle, but this is an extreme use case for maximizing a charge, not using it efficiently.
If at the end of that (say I'm at a campsite in the boonies), I fill up gas and can use "Charge mode" to get that battery recharged, then fill up the gas tank and start over (even a partial charge to get me to a real charger), I think that would completely resolve my range anxiety.
In most cases (for me) a trip will not be 500 miles or whatever, so if I get to my destination (that campsite in the boonies) with 30% battery and can run in "Charge mode" to get it to more like 60-80%, that'll get me back to civilization in most cases (maybe even enough to get me home) - a typical camping trip for me is no further than 200 miles from home (usually less), so the only charger I'd have to use is theoretically my home charger, when I get home. And even on longer trips, it's highly unlikely for me to drive more than 400-500 miles in one day, so if I drive that much, then park and put it in "Charge mode" and gas up the next morning, I feel like this would be very doable.
In normal day to day driving, even towing locally, I'd be well within the pure EV range, 95% of the time. Granted, that's my driving patterns, yours may vary.
This is 100% speculation, and admittedly, I'm a complete EV noob and no idea what I am talking about, so my ideas and numbers may be completely unrealistic, but I have to believe there are a lot of ways to skin this cat. For all we know, that 500 mile range is already doing this to get there (if harvester kicks in at 50% or more, for example, that would pretty much shoot this down).
I suppose it's perfect if you are on the road all day every day.
I daily drive a truck I've personally put 342,000 miles on, and I'm not on the road all day every day.
Maybe once a year I tow across several states. 99% of the time I'm just going to work, a supplier, a customer. 250 miles of range is more than enough for me personally.
But the same people who go, wow, how do you drive all those miles, will in turn demand 1000 miles range towing max rating up a mountain lol. Then part next to me in the lot with their receiver that's never had a hitch in it lol.
Harvester makes people like that feel more secure, and makes it so someone can bring you five gallons of gas and you self recover.
‘maybe not perfect for you, but it would be for me. Use pure EV everyday to go to work, and have the gas for road trips. Perfect Is in the eye of the beholder. I will never tow or haul anything in my Traveler. But I just don’t want to spend a couple hours sitting at a charging station in Yuma. (no offense to anyone who lives in Yuma.)
panzer948
Bryan
2023 Mustang Mach E GT PE, 2021 Ford Bronco Badlands, 2015 BMW M4, 1981 Jeep CJ5
I'm glad you brought up the Volt. I never owned one but a drove seveal and when the ICE kicked in to provide the power source. There was no noticeable loss of performance with the Volt in gas mode. The Gen 1 Volt had a 149 HP that was more than adequate to power the electric motor and charge the battery. Interesting was the planetary gearset to have the engine power the drive wheels when necessary.
The i3 was a different design philosophy (suited for Europe) for the ICE to power the car home or to a charging station.
I see Scout Motors taking the Volt series hybrid approach, which is RAM's approach as well, to sustain the EV drivetrain with enough power to tow continuously, but without the mechanical link to the drivewheels. My hope is Scout does not source an existing automobile engine and repurpose it for the generator application. For cost reasons that was GM's approach for the Volt. A clean sheet engine would be the best design solution; let's hope the budget is there for it.
I agree with all you said except the part about Volt's planetary gearset. That was a myth and was never the case, atleast not in the Gen1 vehicles. The engine was only used as a generator with the battery providing full power to propel the vehicle in motion. What many may have confused this was something called Mountain Mode (versus Normal and Sport Modes). But all Mountain mode did was force the engine/generator to come on to charge the battery while driving; say going downhill, flat, etc. which would increase battery range cushion when you knew you were going to be ascending a long steep incline for several miles (remember the battery range was only 40 miles so a 5 mile ascent was a big percentage of that range). If you started to ascend a steep mountain when your battery was near depletion, you could quickly drop your capacity below a certain threshold that the engine/generator couldn't maintain, atleast at highway speeds; thus putting you in limp mode until you began descending. I owned it for 11 years and that happened once in WV.
What was cool about "Mountain Mode" is it allowed the driver to decide when he wanted to actually use gas generator. For example, If I knew I was going to the next city that would use up most of my battery range on the highway getting there, I could instead put it in Mountain Mode during the commute and force the generator to run, giving me full battery range once I reached said city. This allowed me to be much more efficient while driving in the city versus having the noisy generator always revving up here and there (the Volt likely sounded odd to most folks that heard it from the outside as the engine would always rev up "after"a quick change in motion versus during; this was to replenish battery drop, kind of like a movie when the audio isnt in sync). Mtn Mode also worked well when wanting to show newbies how the car operated in battery power mode alone when you were visiting folks that lived nearly 40 miles away :). Then turn on Mtn Mode to show folks how it operated with gas generator running. Truly two cars in one. That car had a lot going for it.
panzer948
Bryan
Very important to me, if it doesn't work the way you are thinking I likely will not buy
I agree with you, I would rather just get the full EV version and enjoy the bump in performance and range over the gas extender that only prolongs the battery's depletion.
Noplacelikeloam
Andy
Portland
I believe the Harvester, is just an extender, not a multiplier. I think it will kick on at 25% DOC, and run until it's out of gas, and by then you'll want to be at Buccees.
I think that is exactly what will happen.
Jrgunn5150
J.R.
Ionia Mi
A bunch
You're who it's marketed for.
You'll probably never run out of charge on EV either, but the Harvester makes you feel secure.
In reality, if you actually tried to coast to coast with a trailer in one, you'd be filling that little gennie tank every 75 miles because it can't keep up.
But, 99% of people will never actually do that, so they'll never know.
panzer948
Bryan
Ok I appreciate you providing the link to the Volt power train as I do stand corrected. Kudos on how you handled that! : ) I now recall this going back and forth in those initial years as I think the big confusion was how one defines how the gas engines provides assistance. Which as you know, isn't your typical path of most ICE cars and is easily misunderstood. TBH I don't know how GM pulled all of this off as you could never tell you were in some kind of assisted drive mode, usually just the generator riving up "after" a quick use of the accelerater. The engine sound never matched actual vehicle movement as an ICE car.
But this points to bigger concern and the whole reason for this thread. I doubt Scout can provide this planetary gear assist mode if they keep a smaller gas engine in the back like they say. That in turn tells me it will not operate like the Volt could (relying fully on gas if needed). Guess time will tell.
I don't think you'd want a 300 hp turbo 4 cylinder running a generator. You want an engine that makes power at as low of an RPM as possible to optimize KW output with minimal noise, vibration, heat and as efficiently as possible while reliably being able to run at that sustained RPM. None of those things would be happening with a turbo engine.
Otherwise, why wouldn't Ram have paired more than 170hp equivalent kw to a 280+hp engine?
panzer948
Bryan
The Gen 1 Volt top horsepower rating at the primary electric motor was 149 HP. The ICE was a 1.4L naturally aspirated 84 HP engine. A larger engine near or just over 2.0 L and turbo charged easily makes 300 HP. Numerous manufacturers hit this power level with their current engines. IMO, 300 HP is more than adequate to electrically power the EV drivetrain and recharge the battery. Creative tow modes could sustain a battery charge level to boost current delivery to the electric motors when required.
Now where to house the ICE/Generator in the chassis and keep the frunk is the engineering challenge. As someone suggested the Porche Cayman 300 HP 2.0L turbo flat 4 would be a good candidate and could fit under the bed floor (?). The fuel cell easily could fit in a rear quarter panel. Lots of empty space in a pickup bed to utilize.
Anyway, fun to brainstorm the engineering when I have no dog in the fight (other than $100).
Good point about the Cayman. Looking forward to seeing how all of this unfolds, while also feeling we might be helping Scout in someway setting all this up!
ScoutChamp
Buck
Salt Lake City
2010 Ford F-150 xlt , 2021 Hundi Santa Fe
I think this would be AWESOME! they are touting Scout to be a well rounded 8 day a week vehicle. Given its heritage with International Harvester, and their pledge to the 4x4 off road community. I would think they would build in as much flexibility as possible. In the way back time before modern electronics vehicles like Jeeps, were meant to be more utilitarian and useful tools around the farm and in the country. These types of vehicles had power take offs to supply mechanical power to a wide variety of implements from snow plows to electric generators. I hope Scout takes this into account and equip the Harvester option as not only a range extender but also as a modern PTO. A generator to run electronics at camp could revolutionize the overland community.
I've been saying all along I think the engine/generator should be a clean sheet engine design. If the engineers want to keep the frunk, then a flat engine under the bed makes sense. A big bore flat 6 would be neat.
Isn’t the engine in the back? So does it impact frunk? Not directly.
Im guessing the battery will get around 200-250miles. And the generator will have about a 12-16 gallon gas tank. and the Generator will produce around 75-96kw Depending on what variant engine they use from VW.
M3_R2
'18 Tesla M3, '23 M3 LR AWD, R2 reserved. Scout Terra EV reserved.
I thought it was originally implied the Harvester battery would provide 150 EV miles. Which means on a trip or when towing, the REX will be on for much, if not ALL of the time and during towing, I still don't understand how it would possibly keep up.
If the battery was 200-250 miles, that would be quite something! Perhaps you then don't require a super robust engine. At 250 miles driven at 70mph, you have just over 3 hours of range. If the engine is able to add just 50 miles/hour and kicks in almost immediately, that's almost 150 miles of battery range added, providing 2 extra hours to generate 100 more miles, and declining further till you run out of gas. But there's your targeted 500 miles of range pretty easy.
The "overhead" of 250 battery miles would allow a lot more finessing as well as margin of error, for when the generator was active and would also allow more utility when over landing, camping, etc.
DaveGunter
Maine
'21 MME Select AWD comfort/tech, '22 Ioinq5 SEL
It is more appropriate to express the Harvester output as kW than mph.
Using your 70 mph speed example and assuming an efficiency of 2 mi/kWh (non towing) if the Harvester only added 50 mph that would mean its output would be 25kW, which would be pretty anemic for the size vehicle.
Scout has not published Harvester specs yet. Most are guessing in the 75-125 kW range.
