Just an indirect observation. My old Dodge truck had the fuel filter on the fuel pump in the tank. I talked with fleet managers at the time - they knew it was an issue. Pulling the bed was a lot faster than dropping the fuel tank. Pulling the bed was a couple of plugs and 4 bolts IIRC. Modern trucks probably have a few more plugs.
Of course, I used to have a bug - got it down to 15 minutes to pull the motor to work on it. Oh for simple vehicles. In all fairness - I did pull that motor way too often.
Pogeegitz
Adam
2022 Ford Maverick XLT 2.0L
I see the rear placement as too big of an engineering compromise. Any engine is going to have to lay flat or be a boxer architecture. Then there is the reduction in tongue weight and resultant lower trailer weight limits. Cooling system requirements. Ground clearance and under-body protection. And service accessibility; I guess the pickup box gets removed for service and the Traveler has an access cover?
I don't see it happening.
I've heard some claims in other forums that the location of the Harvester isn't the reason for the reduction in towing capacity, but has to do with a different battery chemistry used in conjunction with the Harvester that isn't capable of as much power output. Anyone know which is true?
E90400K
Francis
Toledo
E90 & Mach E
The battery chemistry has most to do with cost and energy density. I doubt there is much difference in instantaneous current delivery between Lithium Iron Phosphate (LFP) and Lithium Nickel Manganese Cobalt Oxide (NMC). The lower-cost, less energy dense LFP does better with short, numerous charging cycles, which it would see in an EREV hybrid application. The lower energy density is offset by the gas hybrid generation.
E90400K
Francis
Toledo
E90 & Mach E
Integrated in-tank fuel filters are common industry practice these days. I have a 19-year-old car with 400,000+ miles on it with an in-tank fuel filter integrated with the fuel pickup. I've never had to replace the filter. The engineering is just better.
Oh it might be a good location for the pump and filter-but kind of sucks when you randomly get questionable gas. I never went over 15k miles without some problems. Dealers would not fix them under warranty - always needed $200 worth of injector cleaner. Eventually figured out it was the filter - went through 3 or 4 of them. Towards the end, I had less than 70k miles on the truck, and it would leave me on the side of the road if I tried anything past a 2hr trip (or it needed another $750 fuel filter/pump replacement). Most of my trips were just under 2hrs, so most of the times no problems - but over 6 months, 4 trips on the side of the road was just too much. Other than that, and the dealerships-loved the truck. Overlanded hundreds of trips with it-just mostly shorter ones.
Funny part was it would die, and 30 minutes later it would run again. I think it was 4 trips in a row-can only remember it dying y2k eve in S. Texas on the way home from Mexico. Died on the way back to Austin from Dallas, died on a date to the beach (we ended up going to a party in Austin instead-and she hooked up with someone else). Next truck-no love for that one - sold under warranty for a great bath. Truck after that, lasted 15 years-but made the short bed mistake so it ended up being a negative life changer - shitty at overlanding.
I miss overlanding. My Jeep is good-but it is far from dependable. Loud, and engine trouble most every trip.
TheConedCat
TheConedCat
1970 Dodge Challenger T/A pro street drag car
maybe they could have a v6 or even a v8
TheConedCat
TheConedCat
This is real out of the box thinking. I don't think this has ever been brought up before!
Yeah I mean the Jeep Wrangler already has a V6 as the base engine and the Rubicon 392 has a slightly detuned (it has 485 hp in normal trim, the Wrangler has 470 hp so that's like 15 less) 6.4L V8 from the Dodge Challenger and Charger. Maybe they could have it optional on other trims but stock on the off-road/performance oriented model (Wrangler Rubicon 392, Bronco Raptor). I'd like it if they named that special trim level "Dune edition".
elvis buys
Elvis
GMC 3500HD
I doubt there is much difference in instantaneous current delivery between Lithium Iron Phosphate (LFP) and Lithium Nickel Manganese Cobalt Oxide (NMC)...
In fact, even with the *same* basic chemistry, there are differences in peak power output vs. maximum energy capacity, depending on the extent to which the cells are optimized for peak power delivery or maximum energy capacity. The former can deliver the most watts, while the latter can deliver the most watt-hours, but has lower peak power output. These are colloquially referred to as 'power' cells or 'energy' cells.
Example - two similar cost 21700 cells:
https://www.18650batterystore.com/products/samsung-40t
4000mAh , 35A continuous discharge
https://www.18650batterystore.com/products/samsung-50e
5000mAh, 10A continuous discharge
This is true not only for the various flavors of Li-Ion, but also for LiFePh. One noteworthy example: the A123 LiFePh "NanoPhosphate" cells have far higher peak power relative to their energy capacity than almost any other LFP cells of the same size.
Characteristics of Lithium-based Batteries
Have we a projected date to when the dreams become realty yet like 3 / 2027 what is the day for which we all await ???
Buzz
BUZZ
ONTARIO
4RUNNER
Hold the horses. My bets on Fall 2028 - spring 2029.
I like to think that 2027 needs to be target to have any chance for Scout to hold sale prices at proposed numbers every year it's 4% more minimum so let's hope the elf's in SC kick some ass and make miracles happen despite the lack of federal support. The Reservation holders need to see feel and touch what they are patiently waiting for getting tired of looking through the glass I personally hope I have an order sheet by end of year.
